Guys, as my engine build comes closer to being finished, I wanted to get your opinions/suggestions on a few parts that I did not buy through the engine builder.
I plan on getting an aftermarket A/C unit, but not sure which or from where to get it. I assume that will determine what brackets are needed for the other belt run pumps, etc.?
That said:
1) Starter that works with TTI headers with X-Pipe Configuration
2) Alternator. Do I need a certain AMP, etc.?
3) Viscous Fan.
4) P/S Pump
5) P/S Gear Box
6) Motor mounts? Can I get heavy duty parts?
7) Windshield Washer pump
8) Windshield Washer motor
9) I want to put the purple beep-beep horn in, do I need a certain relay or electrical set up?
Thanks guys, any help is appreciated. Happy Thanksgiving to all.
Best,
John
3) Viscous Fan.
4) P/S Pump
5) P/S Gear Box
Best,
John
