RonLiv
- Joined
- Dec 7, 2017
- Messages
- 1,462
- Reaction score
- 1,159
Had to get a tow this morning. No fuel getting to the carburetor, again(I think). The weather looked good, mid 50's so thought I'd take the bird out for a drive. Let it warm up for about 5 minutes or so, pulled it out of the garage and put it in park and got out to put the dog in the car. It stalled. Got back in and it fired right up. I had a good 3/4 tank of gas. I drove it for about an hour or so, mostly highway around 65-70, it was just purring along. On the way back to the garage about a mile from the exit going 70, it just cuts out. I get it over to the side of the road and it fires back up. At the exit, it cuts out again, this time it won't start. Cranks, but won't turn over.
Went through all this same thing before, identical symptoms. Put a new fuel pump in (several actually) and a new push rod, and the car ran fine for a long time. The push rod was worn, so pretty sure that was the problem, at least that time. I didn't put all that many miles on it, maybe a couple thousand since the repair. I have trouble thinking its the same thing. But it sure seems to be acting the same way.
When I got it back to the garage and off the tow truck, doesn't the dang thing fire right back up again, like nothing was the matter. The only thing I can think of is the ignition control box doodad. You guys got me out of this mess the last time, any suggestions on what to look at?
