trim88
Been cussing since early this AM. 2 different sources and 2 different stories on how to remove the Hurst shifter handle. I have a 69, but this shifter is out of a 70 or later because it has a "Pistol Grip". One says to insert a .010 feeler gauge into the slot next to the handle the other says insert into both sides of the handle. Neither way has helped me get the damn thing out.
It looks like there is a clip along side the handle that sits between the handle and the frame. Do you slip your tool between the handle and the clip? or do you slip it between the clip and the frame? I've tried both without any luck.
Or is there some other way it comes out?, other than a hacksaw?, which is about the way I'm ready go! Of course being Saturday, Hurst tech is not available.
I certainly haven't been able to contribute much to this Tech section, but I'm sure learning how to ask plenty of questions. and I very much appreciate any help from the pros and not so pro for that matter. :worship:,
Thanks, Jim
Thanks, Jim
