Ignition lock
FJRR
Michigan
Bad ignition lock with 69 RR, key is sloppy, need to replace, original lock.
Hoping for help/ instructions removing and replacing unit.
Thanks for any info.
I saw on U tube on replacing the key switch in a column shift car Road runner. I looked for rebuilding steering column. Mine is a floor shift so the switch is on the dash. But that video was really good. :thumbsup2:
FJRR
Michigan
Russ69Runner, thanks for the info, replaced the ignition lock,starts easy again.
Video was helpful. :beep:
