SgtLee511
I mentioned in a previous post I had ordered a new switch, well I worked all day today setting up this 383 to be fired up after sitting 25 years. UPS as usual late to the game with my switch. So I checked the plug to the ignition switch and Im getting good voltage there, so I try to use the original switch thats missing the key lock, I plug it in, thinking I should get at least the starter to turn over, and nothing. I go to the starter relay and kick her over with no problem. Does that switch have to be grounded?, I had it hanging under the dash. Is there any thing else I should check, Im use to the first generation electronics in my Duster. I also see a box on the back fire wall with a wire going in on both sides above the heater core hose connections, what is that? Im here to learn
