Hey guys,
Down here in South Florida, it gets pretty hot so my engine runs a bit hotter than I'd like. After running her a bit (hot) and I flip the kill switch, the engine runs on a second or two. I've done a little reading on the subject, and seems like it's either an octane problem and/or a timing problem.
Many of you know my build, but in summary: 383 .030 over, Eddy Aluminum Heads and CR is about 9.6:1. Pretty big Comp Hydraulic Cam, and a ProSystems 840 CFM carb, Eddy Aluminum Performer RPM intake, with 1" spacer. Dyno at 440HP/440TQ. I would think that pump 93 would be fine, but the motor consistently does this at shut down. I am pretty sure that they dyno operator set her at 38 advance, but I really don't know too much about this topic.
I'm going to order some octane boost to see if that helps, but what are you guys running your timing at? Any other suggestions? The car runs great, just has this issue at shut down. Like to get it solved before it does any damage. How are you doing on pump gas with similar builds?
Thanks guys,
John
Thanks guys,
John
