BL1 70 roadrunner
Hey guys, I took the car out today and the speedo was jumping and making a clicking sound and as I accelerated the clicking would increase. Is that the little gesr wheel behind that needs to be replaced?
Don't depress it too hard. It's old and brittle and will break off easily. It will still work if you break the lock clip but just depress it lightly and wiggle it while pulling back lightly and try not to break it.there is a plastic retainer, like a finger, on top of the end IIRC, depress it, and the cable housing should pull off. It'll be more by feel than site. It may be easier to pull your radio out, and stick your arm in that way.at least you can be sitting semi comfortably, inside of laying on the seat.
