Just off Idle - Flat spot
RR383
Tennessee
I'm still experiencing the just off idle hesitation...real BAD. Its really an annoyance...I can't even leave my driveway without the car shutting off when I squeeze the pedal. Edelbrock techs claim I need to reposition the squitter linkage to the upper hole. Haven't tried that yet. Agree or disagree? Is the pump shot the only thing that would come into play with the transition off idle?
RR383
Tennessee
:bump:
In addition I changed the AVS setting...1 full turn CCW. Seems to have smoothed out the transition engaging the 4 barrels. So a little progress is a good thing.
dmartin
Hey guys mine back fires through the carb would the be a timing or carb adj I have a holly dual line 750
dmartin
How to tell if you got a bad lifter
dmartin
Also #7 and #8 cylinders are little wet and those two plugs are really black the other six are brown
Dmartin have you done a compression test of those cylinder's Might be ring's. Could be valve guide seal's. Hope that it is something simple Let us know what you find. Those seal's do go bad lot of heat in the back of motor next to fire wall.
dmartin
I hope it's not rings or valve seals cause I put all new in when I did the rebuild
