K member sand blasted and painted
What a job sand blasting and painting the K member was a chore. But it is done. Now to put it back under the car. :lol: I look's like a bone pile hanging every where.
All those parts turned out great.... also like the handicap sign with the bazooka/rifle (can’t tell which in that pic). :thumbsup2:
Did not notice that the main member got dust on it after painting. Had turned on a fan in the shop. It is not stuck to the paint though so it make it look dusty. Lot's of work. Even welded up some of the area's that looked weak and some trashy looking weld's.
Hi Russ. I also blasted k frame and painted it. I also welded the two halves together where it was spot welded. Also I seen information on a form or site somewhere (brain fade again) how to weld supports in spots to strengthen some spots. On the lower control arms I welded metal over the bottoms with 3 access holes. These can be bought. Also Russ I tried start a conversation with you but maybe I didn't do it correct.
I bought it where the rest of the paint for the car was bought. It is not cheap 34 dollar's a quart. Probably should have bought a gallon when starting to use it. :thumbsup2:
Sent you a PM Mo. List was full.
