leak
Roof man
I'm putting on a sticker that going to say these s
Plymouth Mass
Hey guys i'm hoping the anti freeze that came out of the block when i removed the header bolt is normal on a 69 440. id like to change the gasket, but when iot leaked i got a little nervous and put it back in. Please no cracked heads.
4spd69RR
Winter Springs, FL.
Install studs and replace header bolts. That way you don't have to drain the coolant if you have to remove the headers.
