WANTED linkage for 360/904 set up
65 cuda
looking for bracket to go from column shift linkage to floor shift linkage this is what i have i need floor shifter brackets setup instead. i need the 1 where the hole is faced up and alignment shaft on floor shifter can go down through floor and plug into that bushing so that it has a pivot point. needs to be vertical instead of horizontal hole in bracket allows for the shaft to come into it from the top
Try Brewer's. They have a lot of transmission stuff. Hope this help's they are good people. :thumbsup: Or Stevens performance. You can find them on line.
65 cuda
looking for complete kickdown linkage assembly for small block mopar with 904 transmission
May try Summit Racing or Steven's performance in Ala. It is the hunt for rare part's that makes it tough to restore these car's. Good luck my friend.
