looking for bracket to go from column shift linkage to floor shift linkage this is what i have i need floor shifter brackets setup instead. i need the 1 where the hole is faced up and alignment shaft on floor shifter can go down through floor and plug into that bushing so that it has a pivot point. needs to be vertical instead of horizontal hole in bracket allows for the shaft to come into it from the top
