oscartheboxer
After much frustration finally found it behind cigarette lighter. Removed ashtray and lighter frame and found it in back and right next to wire of lighter. Says signal-stat 142 on front its a rectangular cube with bright aluminum cover. Found several overpriced examples on ebay. It is used on corvettes and some honda 750s. Looks nothing like the cylindrical emergency flasher under lower right dash lip. After the usual snafu with ebay ended up using the cylindrical one from napa which works for both flashers.
Beware of the dozens of bogus claims on internet. Some from pros. Do not remove glove compartment liner.
