Making door windows work correctly
ArmyInspector
I had the wrong glass in my drivers door and when I went to replace it I did not know the door glass has holes in it I am assuming for sometype of alignment guide. After I installed the new glass it will not go up straight without holding it in place. Where do I find the tabs that install in the two small holes on the pillar side? Thanks for your help
I think its a part time thing for him I had a little trouble contacting him also
The best time to call him is in the morning from 7-11. He answers most of his calls in that time frame.
earlyrides
SoCal
Re: Making door windows work (almost) correctly
I have succesfully used the little square plastic tabs that you can get at your local parts store to hold on your liscense plate.
It for sure isnt the right way but they work in a inch and fit the hole vey snug.
Early.
