manifolds parts question
generaljmwlee
NEPA
does anyone repop the heat riser setup(have the flap inside need spring and the rest of the stuff) for the HP manifolds
I gutted mine and threaded the holes and stuck bolts in them. Unless you are going concouse or drive a lot in very cold weather, get rid of it.
generaljmwlee
NEPA
guess i should have asked that before I powdercoated them :huh: any trick to tap cast iron?
generaljmwlee
NEPA
no big deal I got taps just not sure about doing cast,didnt even think about it untill I said something about not wanting any exhaust leaks
6R9Runner
Atlanta, GA
Belated X2
I got tired of the put-put-put past the worn-out shaft and exhaust fumes. A 3/8-16 tap worked, didn't even need to drill the hole first.
