Mopar NOS 35 tooth orange speedometer gear w/3.55:1, 3.54:1
CompSyn
Lewiston, Idaho USA
Genuine Mopar New Old Stock (NOS) speedometer pinion gear for 1966 and up Chrysler/Dodge/Plymouth manual and automatic transmissions - SOLD!
It is part number #2538935. It is a 35 tooth orange Pinion Gear. It comes with the original Chrysler packaging dated 08-23-76. It is new and has never been installed in a vehicle.
According to the 1969 Plymouth Service Manual, this speedometer pinion gear is correct for the following tire and axle ratio combinations:
7.75 x 14 (P205/75R14) and 3.55:1 Axle ratio
8.25 x 14 and 3.55:1 Axle ratio
7.75 x 15 and 3.55:1 Axle ratio
F70 x 15 (P215/70R15) and 3.55:1 Axle ratio
G70 x 15 and 3.55:1 Axle ratio
F70 x 15 (P215/70R15) and 3.54:1 Axle ratio
It may work with other tire and axle ratio combinations. Check your references to be sure this is the correct speedometer pinion gear for your application.
