Regarding the bulkhead connection, I can't stress this enough: REMOVE the terminals from their housings and inspect carefully. Brittle? Corroded? Replace as needed. I believe - at last check anyway - that the correct terminals are still available. (If not, use standard terminals available at any auto parts house, and trim the plastic off. They will slide inside the cavities and will not be visible.) If needed, you can modify a standard pocket screwdriver with a grinder to make it thin enough to free the terminals from the connector housings. Then (before re-inserting into the connectors) give each side of the female terminals a gentle squeeze with pliers so they bite the male terminals better. As mentioned, also clean the male terminals... a very fine sandpaper works well...make 'em shine. Re-install all terminals into their respective cavities and pack the females with dielectric grease. When you re-connect the connectors you want to see the grease ooze out a bit.... it means that the stuff is doing what it's supposed to do. Just wipe it off as needed. The above sould be be practiced whenever dis-connecting, re-connecting, or servicing a 43 year old wiring harness, and applies to the dimmer sw, headlight sw, turn signal harness/column connector, fuse box, etc, etc, etc.....Good luck!
