One Person Brake Bleeding kit
TOMRR
Mass
Any suggestion on a Good one , I see they sell them at Harbor Freight , Any ever use one and how well do they work ?
Thanks TomRR
I've used a Miti-Vac for years. Probably a little more $, but I think HF sells them. You can do more things with it, like checking vacuum advances and stuff like that.
The only problem I ever had was my oldest son kept borrowing it and I ended up buying another one.
I know this a old post but I just listen all of them and gravity bleed them. Tighten back up.
I made one out of a broomstick and thin walled pipe and a spring that fits inside the pipe. Works great.
I pump up the brakes insert the spring loaded broom stock between the pedal and seat. The spring loaded broom stick presses down on the brake pedal as
I open the bleeder valve. Just remember to keep the master cylinder full and cap on.
Speaking of bleeding brakes....my RR has vacuum booster and disc up front...does engine have to be running to bleed brakes because of booster ? Any help would be appreciated.
