parts wanted
3BIRDS1X
Moderator
Mukwonago, Wi.
wanted some parts for my next project
door panels in brown they are standard coupe or belvedere I believe the pattern is the same as 68 cars not sure if they had that color available and I may have to dye if I have to.
3BIRDS1X
Moderator
Mukwonago, Wi.
also need this alternator bracket-idler pulley combo and fan pulley too and hardware if possible.
it will be for a 383 I think 440 will be the same but I haven't researched it yet
Thanks
Have you tried Legendary Auto Interiors? They might have those panels - and at a reasonable price, too.
ArmyInspector
another guy is selling door panels on ebay, just do a search, probably can find the brackets also
3BIRDS1X
Moderator
Mukwonago, Wi.
ACME A12 said:
Yep. $301. See below...
http://www.legendaryautointeriors.com/2 ... etail.html
Well that's good to know for the longest time all I've seen repoed were the Blue or black colors in the non-decor pattern, that can now be on the back burner if I can buy it anytime. That leaves the a/c car alternator/idler pulley bracket left on my list of weird stuff. I have everything else to put a chrysler parts dealer installed underdash air unit on the coupe project. I think I'll be going in a unusual direction with that car.
generaljmwlee
NEPA
Classic industries sells the legendary door panels ,and have good discount codes
Picked mine up cheaper than from them directly.
3BIRDS1X
Moderator
Mukwonago, Wi.
cool I'll keep that lead in mind when the time comes
I have all the brackets you need if some one can show me an aftermarket alternator A/C P/S set up that won't break the bank. I'm hoarding, I mean saving them for my Valiant project but it's far from being stock appearing
joewhite440
Industry, Pa
Did anyone hook you up with the brackets. I have the two brackets on a 440 here. I do not know if I still have the Idler?
Let me know if you still need them!
Here's what I have
3BIRDS1X
Moderator
Mukwonago, Wi.
Here's what I have
Not yet I'm still looking for them, I will look them up in the parts book and see if they are still the same and please see if the idler is still around - Thanks
Thanks
Rich I made mention that I would give up my bracket set if I found an affordable aftermarket system but there is no such thing, sorry I'm going to use them.
3BIRDS1X
Moderator
Mukwonago, Wi.
Thanks
Thanks, I'm sure a set will turn up yet I may have to do some fishing on the sea body sites.
ACME A12 said:
Why is an idler pulley required on this set-up? :popcorn:
Ray I think the power steering pump is solid mounted on this system and the idler is where the tension is applied. This is what I pulled off the 70 charger parts car but I would have to look at the P/S pump to verify because it was off when I got it. The belt would go to P/S, water pump, crank, idler. I'm going with a Sanden compressor and an aftermarket A/C bracket. Rich if you can use the A/C bracket let me know, if I go with the low mount A/C I don't need the idler either.
3BIRDS1X
Moderator
Mukwonago, Wi.
I think I'm okay with brackets, but if the idler and alternator bracket is available we will work something out for sure and if you want the brackets gone I can buy them too. As for Ray's question on a/c cars they have a four groove crank pulley, the two closest to engine are crank-compressor-alternator the next one out is crank-power steering then the one closest to radiator is crank-fan-idler
the adjusting parts are the alternator, ps pump and idler.
my coupe will be on a four groove pulley but the third groove won't be used because it will be manual steering still.
