trim88
The service manual for 69 383 says you must use Tool C-3487 to support the rear of the engine to remove tranny. I've never removed a 383 and tranny before. Hmmm, I have to raise the car to get the tranny out and then have to lower it to get the engine out....that is if I do it that way. I can't drop the engine and tranny out the bottom because I only have so much room and must be able to roll the car out of the garage and into a trailer after I get the engine out. I have never seen nor can find a picture of this C-3487 support tool.
So, how do I hold the rear of the engine up while lowering the car down to get the cherry picker hooked up to the engine to pull it?
Is this tool still available somewhere or does someone have a picture of it to possibly make one?
Would appreciate anyone that can set me straight and thanks for listening, Jim
