Rear Gears
Terry Hauck
Choadicus
Mojave Desert
I have a 69 Roadrunner with a bit above stock 440, a 4-speed, and a 509 cam. I have to slip the clutch to get it going with the stock 3.23 gears. What ratio would you guys run, 3.73 or 3.91??
If you want to run down the highway at all 3.55, its about 300 RPM more at highway speed and 300 more for each gear set lower. How tall are the rear tires ? I'm around 3000 RPM at 70 with 3.54s
I run a 30-in tire with a 355 gear at 70 mph on cruise control at 3000 RPM. there's a calculator for this so best to use that.
