roadrunners dead
no juice to the key[ordered a new switch/key/tool/year one and used the 20% code].....have juice at the firewall quick disconnect at firewall but i have been noticing fogging at the speedometer and the amp meter is pegged at discharge......going to do the bypass of that.....to be continued.......all fuses check out too
Roadcuda said:
That doesn't sound good. I hate electrical problems! :brickwall:
you and me both......its going to be a hit and miss thing till i find out whats the problem :brickwall:
6R9Runner
Atlanta, GA
Is the fogging from heat? Sorry to hear about this new mystery/ hopefully its nothing major but watch for ground shorts which melt wires together. Does the ammeter indicate a major draining of the battery?
thats what i am thinking too....i have juice at the firewall disconnect .....i havent been under the dash yet......waiting on new ignition switch also....then i will jump into it
solid gold
Saint Louis, Missouri
Solid Gold is dead also! With all new parts, I called the shop that put it together,(actually 1 guy),He's coming over tomorrow to check it out. Oil light comes on, have headlights,etcs.,but nothing else! It's nice to have service like that! I'm no genius,that's for sure.(I took a couple of your tests before!) :crazy: I'll let ya'll know what he finds out!
all fixed.....tried to unbolt from amp meter.....frozen.....cut splices/crimped/soldered.....still nothing..electric sprayed quick disconnect at fire wall...starter relay main wire loose on terminal......fixed
I'd rather pull an engine than chase electrical trouble.
