Thought I would run this past some of you that have replaced roof and quarter. Where the two meet at the sail panel. The roof has a led joint patch panel bend at off set and so dose the quarter. The roof off set is making it not smooth in this area. Also it sits up higher than the quarter at the window channel. So this is after market metal if any of you have had this problem and found a way to fix it let me know. Russ.
