Schutz Products
Big Block
Jackson, MO
Does anybody know the cheapest place to buy the Schutz Rubberized Coating, Rocker Schutz and the application gun? Summit has increased all their prices quite a bit. Thanks!
Why wont the East wood bed liner gun work I sprays that stuff. May be it will spray the Rock shield also. Russ.
Big Block
Jackson, MO
The gun I bought was for spraying the rust converter like fur tan through it and hard to get area as it has a small tip on it it does not have a big barrel on it so it probably wouldn't spray that thick stuff. I had a hard time trying to spray some pro 15 through it. it did not like it plus the gasket is made out of some kind of foam and when I clean the gun it ate up the gasket,the lacquer thinner did. I made a gasket out of some gasket material for gas tanks and I am going to see how that works if it will spray.
I bought the undercoating from Resto Rick and the Shutz gun from Amazon. Gun was way cheaper than the undercoating...
