sam z
Ok, I've crabbed here and there before about the carb I'm using. If anybody
forgot, I'll remind you: Holley #4779 750 DB mechanical secondary. Three annoying issues
right now: 1. The bog from a dead stop, 2. The smell of fuel (lots of it) after running the car hard and 3. The fact that it runs rich after constant tinkering and adjustment. Many of you have chimed in and hinted that this isn't the best equipment for street use, and Mopar Performance says quite similar. According to them its a racing carb. Internet searches have also revealed that this model has the bad tendency to run rich as I complained about a second ago.
I want this thing gone, and I want the RIGHT equipment for what I have and what I plan on doing.
This is what I've got:
1972 440 HP w/346 casting heads
MP 484 cam
3.91 sg rear
Holley street dominator intake (which Mopar perf. speaks highly of)
Headers
Automatic (as far as I know OEM)
Electronic ignition
I want this car to do a few things:
-Run properly and not friggin' stink like a gas station
-Launch and pull hard with the gears that I have
I believe that I have the ground work for a good performing car. The leak down test came back with excellent results when I had it done. I have no interest in changing the cam in the car at the present time. I realize it is older piece but it is still good equipment. If a torque converter swap is recommended I have no problem with this because the engine is coming out at some point anyway and I'll gladly put in another piece at that point if its beneficial.
Thanks guys. I'm looking forward to any and all responses.
MP 484 cam
3.91 sg rear
Headers
Electronic ignition
