Shifter Question
Dusty
Oregon
i have a 69RR, medium build, bench seat. It has a hurst shifter and linkage, I would like to use a pistol grip. Will this work? Is it just a bolt on
Thank you
If you can see two bolts holding the shifter handle on, it's a simple swap. If it is the original shifter I think you need to take the shifter about halfway apart to swap it out.
or just swap a complete Pistol Grip shifter. I had one in my last two cars, loved it. But this was when they were affordable.
swapped my hurst slapstick out a few months back, as long as those 2 holes arent too worn, your shouldnt have too much trouble with the switch. mine were pretty sloppy, so had to "persuade"it a little bit, but it got there
Got to swap my long horn shift handle to the console handle. Hope it dose not give me any trouble. Let's see some pic's
