Signal Light Switch
CWR
I need a signal light switch, i believe. The lever now has no tension in it........Just hangs limp!!! I think its made of plastic and comes with wiring..........Can anyone guide me to where I can get one? Might be easier if I can pick a few small brains in here!!
CWR
Got my signal light switch from local NAPA store. Only $20..Finally got the steering wheel pulled to have a look. To my surprise the switch had been replaced.............Made in Tiawan stamped on it.Switch was ok. Screw holding lever was loose.........tightened it and all was good. Easy fix for once!
