I finally got mine to work and be accurate!!!
DANG!!!
This made me crazy since my 6BBL bird can really eat some fuel but I finally got all of the bugs worked out.
I have a standard dash first of all so my fix for the dash side will only apply to that.
My gauge would sometimes work and sometimes not. Mostly it would work on cold moist mornings. Then later when it would warm up outside; it would drop to below "E".
Also when I would top off the tank on the working days; my replacement sending unit from Quanta products would only read 3/4 of a tank.
So one day while I was cruising through the swap meet at the Spring Fling Mopar show I scored a standard dash cluster for $10 bucks. (WHOOHOO!!)
As I stared at the back of my swap meet dash cluster I noticed that the fuel gauge had 2 nuts that made the connections to the circuit board. That is when it occurred to me that maybe these nuts were just a bit loose or maybe there was a bit of corrosion on the units on the dash in my bird.
So I went out to the bird. I disconnected the battery. (VERY IMPORTANT!!) Then I very carefully reached up behind the dash and felt my way by braille until I located the 2 nuts. Then I put my socket on my flexible nut driver and turned each nut back and forth a few times in case it was corrosion and went an extra 1/4 turn in case it was loose. Once I reconnected the battery and turned the key on, BINGO! And you know what? The danged thing has worked everyday without fail ever since.
Now, for the sending unit calibration. When I emptied the tank of fuel and had the key on my gauge would be about a 1/4 tank below "E" at the bottom of the sweep. So I grabbed the tool that I had purchased from Quanta product to remove the locking ring. (this isnt the only way to get the locking ring off but it is by far the easiest if you have to go in and out with the sending unit.) Once I had the sending unit on the bench I took the cover off of the resistance wire and sweep arm to see what was in there doing all of the "magic". Well heck; it was just a small brass arm pressed onto the metal arm that holds the float. So I gently persuaded the brass arm about 25% up the sweep and reassembled the cover and re-installed the unit. This time with the tank empty and the key on the gauge went just a hair above the "E". DANG! I went a bit too far. So out it came again to back off my adjustment. The next time I tested it with the tank empty and the key on it came up to one needle below the "E". I figured this was good so I would always know that even on the "E" line there would still be a bit left to get to the next "drinking fountain" for the car. Next I put in one gallon and tested it. To my surprise it came up about a half needle. Then I added 2 more gallons and it came up above the "E" mark.
So after many years of wondering if I was going to run out if I didn't keep putting in $30-$40 bucks every time I took the bird out, now I cruise with confidence knowing the "E" really means "Enough" to get to the next gas station and that every time I turn the key on that my gauge on the dash was working.
I hope this helps someone out there experiencing the same thing I was. Since then I have done the same with my 70 Bird, the 69 Vert Bird, my 68 Satellite wagon and my 66 Coronet too. And they all work great.
