Starter wont turn!!!
Bill Monk
Dunbar, WV
New to the site but not to Mopar, had em when you couldn't give em away, now you have to mortgage the house! I'm stumped on this one people so here goes:
69 roadrunner, original 383, now with a 440 6bbl. Original 4 speed car, still is. Just bought this car and already loosing more hair. Starter would not attempt to turn the flywheel. It just made a single pop when the solenoid kicks in and it engages the flywheel. Battery is good, grounds are good to block and firewall and both battery cables are new but still cleaned connections. Thought for sure it was the starter since it was starting fine and then suddenly stopped. I replaced the starter with a mini starter and I still have the exact same thing...a single solid pop when the solenoid does it's thing but the starter doesn't turn the engine. Yes, I turned the engine by hand and it isn't locked up. Help a brother out!!!!
Coyote
Columbus, OH
Try a load test on the battery. It may have an internal problem under load. Good luck, let us know.
Bill Monk
Dunbar, WV
Thanks but it does the same when I jump it so unlikely. This one is making me nuts
dmartin
Have you checked the starter itself or the bendix what about the connections to the battery and the ones to the starter it usually is something simple
Did you test the new starter before installing? Just because it is new does not make it good.
It really sounds like a bad connection at the battery, starter or ground or a bad cable.
You can do a voltage drop test on the cables to check that. http://www.aa1car.com/library/voltage_drop_testing.htm
I'd also check the voltage at the battery when the starter engages. If it drops way off, it's a battery issue.
Hello what the heck. May be a bad ground to the motor. Have you jumped the starter relay to see if it was bad. Had a tractor that we looked every where and it was the ground at the motor not making good connection. Also had bad relay jumped the post with a big wire. Well take the starter out and see if it turns while hooked up to the system. Yes one small thing will drive you crazy had a bad battery one time the head light's would come on but not enough power to turn the motor over week cell. I don't trust jumper's put a new battery in and try that. Hope you find what is the matter and surely let us know. Russ.:cartman:
Bill Monk
Dunbar, WV
Thanks to all, I didn't play with it yesterday. I'll tackle it again this evening.
Ranger
Woodstock ll
Jumping a battery with a dead cell won't accomplish anything and you'll get the same result. Follow Big John's advice and either do a load test or swap out (or bypass) the battery for a known good one to eliminate it as the problem.
I was looking for a better way to explain voltage drop and found this.
[video=youtube;DfLyh43iihM]https://www.youtube.com/watch?v=DfLyh43iihM[/video]
Bill Monk
Dunbar, WV
Ran the voltage drop test and found the primary battery cable was dropping 7 volts under load! The cable looked new, but that goes to show test everything first and save yourself a lot of time and trouble! Special shout out to Big John for posting that video. Note to everybody, watch this video and buy a good multimeter!
Bill Monk
Dunbar, WV
Thanks for posting this video man, I appreciate you
dmartin
It always is something simple
Glad you found the problem. It always the last thing you would think it is. Give big John an big atta boy sound's like he's been their before.:applouse:
