Steering colum problem
bschomske
Rochester, New York
I have a small problem with the steering colum,the part where the automatic shifter mounts and where your gear indicater is.The whole part of this is loose.Is there a kit you can buy to fix the problem or how to you fix this problem? Thanks bruce
Beekeeper
TN.
Hey Bruce,
There is a set screw on the collar that's in behind the gear shifter. This set screw could be loose causing the loose condition
