Tach
toms69rr
Atlanta Georgia
OK guys here one for you
Since I change over to an electronic ignition. My tach dose crazy things: jumps up to 7 grand back to 3 then to 5 you get the ideal.
What do I need to do to fix this, any ideals?
Shielded wire? Some kind of resistor?
I’m open for suggestions
toms69rr said:
Re-pop tach, red line gauges redid the whole panel with the updated stuff
Summit brand Electronics
id be calling up summit....did you follow the directions for hooking up the tach......mine on the msd hooks up to the box....or a bad ground wire or recheck wires for chaffing and shorting out
