Not RR-related, but here's a tachometer issue for someone more electronically savy than I:
Put a new Summit (Mallory) Electronic Distributor in my '74 Duster today. The one that was in the car was one that I had run in one of my other Dusters back in the '80's; It served me well an couple of different engines but had gotten a little worn... I did not change the ECU or make any other changes to the ignition system. I did install new plugs, and I disabled the vacuum advance so I am relying solely on the mechanical curve in the distributor now. Initial timing was dialed in at 18 degrees with 34 coming in at 2,000 RPM. I then hooked up the vacuum gauge and piddled with the carb (Holley 750 0-80508S) until I was pulling about 15"Hg at idle - decent for a 340 with a Comp XE274H in it I thought. The huge off the line bog that I had been experiencing lately is now gone and it is running great again. It's now ready for the trip over to Kissimmee to hang out with Johnny McMoPar next weekend.
So here's the rub - suddenly my tach (Autometer Street Tach) jumps all over the place at idle (1,000 RPM in neutral or park)... :huh: It was always steady as a rock before, but at anything less than 1,500 RPM it's jumping like a mexican jumping bean. One irregularity that I noticed when I set up the distributor was that the air gap between the pick-up and the reluctor was not uniform. I set it at .008" (Ma MoPar recommended) on the two tightest points and have about .011" on the two widest points. Any idea if perhaps this might cause what I'm seeing, and if so, why does it clean up when the engine speed is increased? If anyone has any thoughts please let me know. Just kind of aggravating...
ACME
ACME
