temp wire bulkhead location?
metalstorm
Cleveland Ohio
The short story is I need to know where the wire is located in the connector on the bulkhead on my 1969 Sport Satellite.Thanks for your help![purple wire]
Looks like in my wiring diagram it goes into the hole marked with an "R".
If it's not marked goes across from the dark blue wire.
I need a little more help than that I am afraid.The engine side of the plug is not there so I need to know which port like lower#3 from master cylinder middle 2 rows.Sorry for being a pain!
Thank you!!!
My diagram shows a purple wire looking at the firewall going into port R which is the middle plug top right
That is where I have the fuse link,I think it goes below that.
Bob is correct on where it goes inthe top hole.
What color is that fuseable link you got in the top hole?
if it's dark blue it goes on the other side of the purple wire as it's for the starter relay.
This is in the middle plug,top right hole on engine sideor left.
my fuse link is faded blue in the top rt of the middle plug.The car starts fine with the key and power to lights and all.I had a copy from a manual but cant find it.
