This is heighth and wheel clearance
Did not get a picture of the clearance between tire and body so wanted to add this picture. Russ. IMG_0101 (2).JPG
Looks like its going to have a rake even after more weight is added but they do settle some
Yes Bob it will crouch a little more when the car is finished I assume once it is finished. It should be a lot more weight their. Will see. But I do like the higher rake to give it that 60's look. Oh with the cooler in the trunk loaded with beer will also help. :lol:
You know Quick Bird I put a cooler on the back of my four wheeler. Road around for a while stope to get a beer and the can had exploded. From shaking them up when riding. That might happen in the trunk also. Russ.
dmartin
If it gets to close you can always crank down on the torsion bars
