Tranny Rebuild - Did I pay too much??
JJRJR
I had my 4 speed rebuilt for the 69 RR. I do trust the tech doing the work, but it seems like a lot of money. Guy said the whole tranny was frozen up and they essentially made it into a new trans. Price as $1,100. Sound right?
Thanks,
John
3836bbl
Was it in the car working before you took it out?
Need more info on why it was removed,and did the shop remove it,
or did you remove it and take it to them?
John
SomeCarGuy
Sometown in KY
That's what Brewers charges for a 23 spline outright.
If they took it out and put it back in, then you did fine. Even if you did the r&r, it may have saved the shipping costs. Last card is quality. Brewers is top notch. If these guys did it right then you did great.
JJRJR
It was in the back seat. They just came and picked it up. At the end of the day, they said it's like new now. Thanks,
John
Is it a 4 gear? I forget. Anyways, it depends on whats wrong with it. I have been guilty of spending over $1500 to make a trans perfect again and I did all the labor myself (including rebuilding it). So depending on what was wrong with it, $1100 sounds like an appropriate amount.
sixgunrunner68
Yeah, it definitely depends a lot on what parts you need. Once you have to start buying gears the bill starts to tally. I was pretty fortunate when I had Jamie Passon do mine along with sending my shifter out to get rebuilt and replated the bill only came to about 800 bucks and two hundred of that was just for the shifter service. I dropped it off and picked it up.
abodybill
Senior Citizen Member
MI. Farm
Just picked mine up from Jamie at Passion at Carlisle this year and with exchange it was $700.00 with all made in the USA parts :thumbsup:
Jamie stands behind what he sells to!
JJRJR
Finally got the work order for the tranny rebuild. Here's what it says:
Rebuild transmission with all new bearings, blocking rings, seals, main shaft, synchros, gear set, spacers, etc.
$1,075.
Sound reasonable?
$1,075.
Sound reasonable?
Yep the shafts and gears add up in a hurry :yesnod:
