Trunk Support's
Dose any one know if 69-70 charger hinge support's will work on a 69 road runner mine are well you guy's know rusted up pretty bad. It look's like any thing from the rear window filler panel down is in pretty bad shape well thanks guy's even if you don't know chime in.
I know the Charger lid does not weigh as much as the Road Runner lid. Might be a lighter spring. Compare part numbers.
A12
If 23-19-181 is the part number that you're asking about, my '69 parts info shows the same parts for every '69 B-body EXCEPT the "27" convertible and not used on B-body station wagons (45, 46) of course. It also shows the left and right brackets are identical or "qty. (2)" for body type 21, 23, 29, 41-(4dr coupe), 43-(4dr sedan). "29" is the Charger, is that correct?
