Turn signal flasher location
s/w theo
1970 Road Runner, factory 383,4 speed car. We found the 4-way flasher but can't see a turn signal flasher anywhere. Where is the flasher for the turn signals located? I think all the Mopars that I've ever worked on have a flasher for each. Do these cars have a single flasher for both? We are running LED bulbs & the flasher that we are installing is the one with the ground wire on it. I understand you need this one to run LED bulbs. Any help?
Can't say for sure. Mine is a 69. One flasher was on the right side of the steering column and the other was on the other side. Just under the dash. Hope this helps. Russ.
Thanks guys. I found the e-flasher on the right side of the steering column. I will look more for the T/S flasher tomorrow. I know I'll find it, was just wondering if they hid it behind the kick panel or something stupid like that. Not too easy looking up under the dash at my age, + the shifter & stuff being in the way.
Don't know about 70 but 71 has one on right side of steering column and the other under the dash attached to the back side of the ash tray.
Found it! It was on the right side of the steering column under the dash. E-Flasher was near the ashtray under the dash, if anyone else that has a 70 Road Runner runs into the same situation. I don't why Chrysler would change locations from a year earlier, but hell, they might be in different spots on a 70 too! They did do strange things back then.
