Turn signal switch
I have a broken turn signal cancel cam. Do these $10. repair kits work or do you guys suggest getting the $140. switch w/harness
No hands-on experience there myself Bob, but I would think that for $10 the repair kit might be worth a roll of the dice...assuming you can ascertain the effectiveness of the repair before you have EVERYTHING all bolted back together... :cents:
I replaced the switch and harness after getting mine back and discovering a broken return cam and intermittent problems with the left rear brake light and turn signal. After the replacement all the problems were solved and the lights actually are a little brighter now, too! :thumbsup:
I was going to put a kit in but I found a local guy that sells the harness and switch for 52 bucks :thumbsup:
