Valve Covers
JJRJR
So, it turns out that all I needed to do was tighten the bolts on the covers and the leak appears to have stopped. What is the trick to getting a socket on those bolts. The MP covers leave ZERO room between the cover and the bolt to get a socket in there, so it was a real pain in the ass.
Can I get a thinner walled socket someplace? Put her up on ramps and she looks pretty good. Looks like the oil was leaking from the bottom of the valve cover and all down the headers, so it got them pretty oily.
Need to get a better socket though, any ideas??
Thanks,
John
JJRJR
Oh well, not as easy as I thought. Still leaking onto headers, can't tell where from, maybe the bottom end of the valve cover gasket. Seems to have fixed the leak on top, but still something coming out. Have to get up on a lift.
dutchrunner
The Netherlands
Had torx bolts on mine.
Or get allen bolts.
No room issues as the spanner goes inside bolt and not around.
JJRJR
Or get allen bolts.
Great idea!! Thank you.
1/4" drive 12 point socket is what I used with no issues. What kind of gaskets did you use? Over tightening will ruin some types of gaskets.
JJRJR
Don't know what gaskets Gary used. I bought a set of MP. Looks like I'll need to change them. I did use a 1/4" drive and a deep 12 point, but still no room between cover and bolt to get in there. It's a slow process, but we were able to get them tighter. Bad design if you ask me.
I like the allen bolt idea.
get some cheap Chinese sockets from Harbor Frieght,Big Lots,etc. usually really thin walled.
