I recently pulled out the vent windows on my RR as part of doing some interior work. I could use some new HW for them, specifically the gaskets and screw which are part of the upper pivot (bolt through the glass). Is there a source for these items?
Also found out that on both window frames, the "leg" with the channel for the window has a seperate piece which looks to have broken off of the "leg" Looks like they were orignally staked on to the leg. Anyone else had this problem and how did you repair?
Thanks,
Bob
Thanks,
Bob
