If removing amp meter connect the 2-10ga. wires together, can also connect volt meter positive; negative goes to ground. Amp meter wiring must be complete for charge circuit, it’s in series. Volt meter can actually be placed anywheres with alternator voltage present.
Don’t of coarse connect to battery so it stays active all the time, just when charging.
