Ranger
Well today was resurrection day. She was a bit obstinate and I had to adjust the choke, but she finally lit. Took her out for a drive and I noticed the volt gauge pegged at 16v. The factory amp gauges was also near pegged, but then they'd drop and bounce back. A few times I even noticed the tack bouncing around.
Figured it was the voltage regulator so I checked the service manual. Hard to understand it, but I tried a "manual adjustment" (slight bending of the contact spring tab). I think I have it staying around 13v when running the RPM up to about 3500, but I won't know for sure until I drive it again.
Speaking of the Tach, does 3300 RPM sound right at 60 MPH with 15" wheels and 60 series tires on the back with a 3.23 rear end? When I used an online calculator I came up with (and expected to see 2600 at 60 MPH).
The tach is a Sunpro SST802R 3-3/8" Retro Super Tachometer
