I'm pretty sure that the voltage regulator on my Barracuda took a dump. The electrical system has been acting strange, and when the car is running it only shows 12.6 volts. I tried pulling the neg cable off while it's running to check the alternator and it kept running. So I took the regulator off and opened it up. It is an electrical unit and has that burnt electrical smell. I tried to check the continuity with my tester and it shows nothing. It will show some to a few places on the board but not all the way through. My guess is that it' has gone bad. What do you guys think? Thanks.
