Water pump, 6 vane or 8 vane?
SpursN17
Lincolnshire, UK
I need a new water pump and I've seen two versions, a 6 vane, and an 8 vane. Which one is the correct one to order?
There's no air con on the car if that makes a difference?
Cheers
Dave
Hemifiedbird
Red Deer Alberta
The one with eight will give more water flow, but if you are not having a issue with cooling and yours is 6 blades then that’s all you need.
383 without air used 2808680 pump
383 with air used 2808681 pump
I assume the 681 pump was 8 blade
Exactly right on the fun. If there weren’t any challenges in life what would be the point. Great satisfaction for me when I get one of these solved.
