I talked with Kevin at Hughes and this is the cam he sent me with the springs and lifters. What are your thoughts?
Return to Parts List
Category : Big Block 383-361-400 (Low Deck) : Camshaft : Flat Tappet, Hydraulic : Muscle Car
HUG HMC2942BL-7
383/400 MUSCLE GRIND CAMSHAFT
WHIPLASH SERIES FLAT TAPPET HYDRAULIC CAMSHAFT
$215.00
Whiplash Series Flat Tappet Hydraulic Camshaft Drop in Muscle Car Cams. Want that mean 60's & 70's muscle car lope without doing a complete rebuild? You need one of our muscle car cam.
No machine work, leave the heads on, raises cylinder pressure. Ground on true .904" cam lobes. This gives you max area under the curve. Has low lift to clear guides.
SHAKE, RATTLE & RUN!!!!
You can feel your car transforming!!!
These HMC cams have bad-to-the-bone idle, very quick stop light to stoplight acceleration! Idles like a funny car but smooths out above 1600-1800 RPM.
These cams are designed to drive better than the sound would imply. These are killer cruising cams made for low compression (8:1-8.75:1) engines and are designed so the cylinder pressure will not be reduced (Torque Killer!) like other cams of this size or type.
Camshaft Technical Details
Intake Valve Lift 1.5
Exhaust Valve Lift 1.5 .518"
.518"
Intake Valve Lift 1.6
Exhaust Valve Lift 1.6 .552"
.552"
Intake Duration at .050"
Exhaust Duration at .050" 229°
242°
Lobe Separation Angle 107º
Intake Opening at .050"
Exhaust Opening at .050" 10.5° BTC
51° BBC
Intake Closing at .050"
Exhaust Closing at .050" 38.5° ABC
11° ATC
Min. Suggested Cylinder PSI
Sweet Spot RPM 1800-5200
Thanks,
Barry
HUG HMC2942BL-7
$215.00
.518"
.552"
242°
51° BBC
11° ATC
Thanks,
Barry
