What is oil pressure at idle
Engine & Related
  1. richardgoesfast
    richardgoesfast Active Member
    26
    May 5, 2019
    On my 1970 with 383 my oil pressure at low idle is 20 and if I take it up to about 1000 rpm (in neutral not on road) it goes up to 40. Does that sound right? Couldn't find any info on this anywhere, figured you guys would know. Thanks.
  2. quikbird
    quikbird Well-Known Member
    2,335
    columbus, ohio
    Sounds pretty normal to me.
  3. richardgoesfast
    26
    May 5, 2019
    Thanks, appreciate the input.
  4. whayden2003
    whayden2003 Well-Known Member
    59
    May 17, 2017
    Louisiana
    20 @ idle is actually pretty good in my opinion.
  5. 69hemibeep
    20,150
    Yep
  6. Russ69Runner
    2,382
    That is pretty darn good. :thumbsup:
  7. richardgoesfast
    26
    May 5, 2019
    Thanks, this is a real relief to me.
  8. Ranger
    Ranger Well-Known Member
    1,278
    Dec 25, 2014
    Woodstock ll
    That's right about where mine idles at.
  9. ‘69_Sunfire_RR
    ‘69_Sunfire_RR Member
    22
    Jun 9, 2018
    Same here, my ‘69 383 idles at 20 when warm or about 185-200 degrees. Bring it up to 1000 rpm and it’s at about 40. When cold I get about 70 psi but just at startup. What degree thermostat you all running?
  10. richardgoesfast
    26
    May 5, 2019
    That really parallels what I'm seeing. Thought it was low because I have a 2015 Mustang which has a much higher pressure at idle. I'm still new to this car, and trying to get it back into running condition after living in someone's garage for a bunch of years. So, don't know what the thermostat temp rating is. I just fire it up and try to get it to idle.
  11. ‘69_Sunfire_RR
    22
    Jun 9, 2018
    I hear you man. For reference my wife’s brand new Tahoe idles at 20 and peaks at about 35-40 when driving (1500-2000) rpm. And that’s normal. Like you I’m used to much higher pressure but with my RR it just seems normal. I researched this a lot when I bought the car and everything I read parallels what we are seeing.
  12. Ranger
    1,278
    Dec 25, 2014
    Woodstock ll
    180°
  13. richardgoesfast
    26
    May 5, 2019
    Thanks.
  14. moparchris
    moparchris Well-Known Member
    4,785
    Feb 8, 2009
    The general rule of thumb is 10psi per thousand RPM its at. Oil pressure is measured at the end of the oil passages, so even if you had 1 psi idling hot then you would have enough because you probably have 20 psi at the main and rod bearings. As long as it comes up to 50 or so at shift RPM you are good to go. Most folks worry about oil pressure and want extra oil pressure like a savings account or something. It doesn't really work like that. Extra oil pressure is just straining the pump and causing extra heat in the oil. Oh and by the way coolant temp has very little to do with oil temp.
  15. ‘69_Sunfire_RR
    22
    Jun 9, 2018
    Thank you for this explanation. It makes great sense to me!
Share This Page
