What is the timing of a 1969 383 built September 1968
nicanor
I believe I'm reading the book and correctly timing the 383 in my car at TDC on the #1 sparkplug wire. Is this corrcet for a 383 built around September 1968?
Thank you,
Barry
Set it to 36-40 degrees total timing with the vacuum advance disconnected. You may have to run less if you have pinging problems with the quality Ca pump gas. If it does ping at 40 then back it down in 2 degree increments until its gone then take 4 degrees off that to be safe.
and that is around 3000 rpms and the vacumm hose should be blocked off[cardboard/paper/tape] so its not suckin air
Thanks George, I forgot to mention that.
SomeCarGuy
Sometown in KY
I found that my 383 HP liked 34 total. Ran MUCh smoother and pulled stronger than 36 or 38. Even though it didn't ping at those levels. It really does pay to play around and see what it likes. No two combos can really be compared though. The local gas and particular tune plays a role.
