69hemibeep said:That's what it is, just tie it down to the harness. :yesnod:
Yes. I know the gray matter in your head gets cold this time of year but if you read his post really slow you might pick up that he asked if it was the temp sending wire in which I responded "That's what it is" :acme: :acme:abodybill said:Isn't that the plug for the temp. sending unit?
69hemibeep said:Yes. I know the gray matter in your head gets cold this time of year but if you read his post really slow you might pick up that he asked if it was the temp sending wire in which I responded "That's what it is" :acme: :acme:abodybill said:Isn't that the plug for the temp. sending unit?
Now that's funny right there!!!abodybill said:69hemibeep said:Yes. I know the gray matter in your head gets cold this time of year but if you read his post really slow you might pick up that he asked if it was the temp sending wire in which I responded "That's what it is" :acme: :acme:abodybill said:Isn't that the plug for the temp. sending unit?
Just come in from 4 hrs. plowing on an open tractor so I had more gray matter then normal.
And this comes from the guy that don't know when his birthday is :jester:
