- Joined
- Sep 8, 2008
- Messages
- 5,059
- Reaction score
- 83
OK.. its a little difficult to remove a Roadrunner windshield. Years ago, I had a windshield guy show me a few tricks of the trade and I've had pretty good luck since then.
First, and even though I'm not a "numbers" freak, I took a pic of the date code because you never know.
Next there's the removal of all the chrome. You use a KD-tool #2037. I've bought and lost about three of those over the years. Usually I lend it to someone and forget who has it... but whatever.
You use the bent end to get down under the chrome and unlatch the clips. Its another one of those things that some Chrysler engineer is still laughing about. Then you take the end with the little ball on it and stick that into the gasket and pull it all the way around to unlock it. Spray the gasket with your favorite spray lube (I like PB-Blaster) to help it release.
Then you get in the car and lay on your back and gently push against the windshield with your feet being careful not to......
crack it...
crack it...
