Hoosier Bird
Tore into my z-bar to make sure everything looked good and guess what? More work to do....... :brickwall: The ball that screws into the bell housing was bent, ground on and tightened up with channel locks........ :brickwall: The ball that attaches to the frame has been broken off and rewelded, which I think is why they torched the bracket, so it would sit flat with the big weld on there........ :brickwall: Only the frame side had the plastic bearings in it.........so I ordered a rebuild kit for the z-bar. It has clips and everything in it......
